Display Host processes on Dashboard
3 processes from the host are not discovered and displayed in dynatrace. what can be done to view this process in dynatrace
You can create your own Declarative process grouping.
I recommend you reading Process group detection also.
Best regards
@AntonPineiro  Thanks for your reply
