Good afternoon everybody.
A newbie question: I registered for trial and installed the software on windows and linux machines.
When I try to look at logs I can see a list but clicking on them I get nothing.
For example this is a windows machine with 3 logs
When I click on a log (any of them) I get this but not log info
Same for this where I can see the mongo log in the directory structure
but clicking on it I get nothing
Do I need to turn on something to see/enable log monitoring?
Thanks in advance
G
Hello @gshemtov
By default, all Log Monitoring hosts are monitored. Please have a look at the below link for more insight:
Babar
I did 2 things and suspect one of these made the difference:
1. install activegate (that was in the context of trying to monitor k8s).
2 I went to settings > log monitoring > Log source and storage
chose “include the following logs” from the drop down , checked the machines and saved the changes
Anyway, it is working now.
Golan
Hello @gshemtov
Glad to hear that you have resolved the issue.
There are two things, I did not mention in my last comments:
- OOB, logs stores on the host for the last 7 days which are available on-demand from the specific host.
- The other way is the central storage (NFS) for the long-term storage (30 days). Log viewer use for this purpose as source and storage to save and analyze the logs.
Babar
