We need to install OneAgent on a linux server and the client asks for prerequisites of installation, so i took a look to the documentation and we find the table describing storage recommanded for every directory :
| Linux (x86) | Default directory | |
| Size of installation | ~1 GB | /opt/dynatrace/oneagent |
| Persistent configuration | ~5 MB | /var/lib/dynatrace/oneagent/agent/config |
| Temporary files, runtime configuration | 200 MB | /var/lib/dynatrace/oneagent/agent/runtime |
| Logs | 1 GB | /var/log/dynatrace/oneagent 2 |
| Crash reports, memory dumps | 3 GB | /var/lib/dynatrace/oneagent/datastorage |
| Additional space required for updates | 1.9 GB | |
| Total | 7.1 GB |
Does that mean that we have to create File systems for /opt/dynatrace/ , /var/lib/dynatrace/ and /var/lib/dynatrace/ ?
Thank you.
