Documentation - Short links working?
Are your short links to documentation working?
Short link → About Dynatrace Documentation — Dynatrace Docs
Full link → https://docs.dynatrace.com/docs/get-started/about-documentation#how-to-share-links-to-dynatrace-documentation-topics
I am getting an error with short links normally:
Is this happening to you?
Best regards
Hi @AntonPineiro I’ve noticed the same and have submitted feedback to the docs team.
Update from the doc team:
Thank you for reporting this. This is a known issue reported by others, and we’re working on resolving it.
Hello Anton,
Thank you for your feedback, we are aware of this issue and we are working very hard on fixing this. The good news is that we identified the issue & fixed it. So, we should be releasing the fix as soon as possible. Currently, we are in process of testing it and verifying the fix.
Adham
Hello Anton,
We have released the fix and it should be working. I also checked the link you provided and it works as well.
Sorry for the inconvenience,
Adham
Thank you! Yes, my initial short link, in this thread, is working perfectly.
Best regards
