Is it possible to capture DB2 and WebSphere Application Server data on IBM i (i series, AS400)?
@tfukuda WAS and DB2 monitoring on IBM i (AS400) is unfortunately not supported.
@_Alexander_
I got it, thank you for your answer.
hi, good morning. Let me talk about a use case applied in a past client where they used an IIDR to capture every events on DB2 and post the content in a kafka queue of a middleware server. After, the queue was consumed by a microservice that record the event in a relation database. All the monitoring content was applied on this replica process, except by mainframe environment.
