I am trying to use the existing selenium tests using dynatrace for test automation. Is there a way we can achieve this using dynatrace? If not, could you please provide a reason why and consider adding this feature?
Sri harsha
Sri harsha
You can! as long a browser and the RUM agent is loaded all info should reach DT. You could check this? kinda old but still apply:
