In Classic Log processing, I’m trying to process content that has what seem to be nonexistent escape characters:
I’m trying to extract “asousa” but with no success. I can get partial results, but I can’t even “Save changes”…
Any ideas?
Thanks for the suggestion, but in my case, in content, there’s only one ‘\’ …
Hi @AntonioSousa ,
The log sample in the processing rule config is a JSON file. The additional backslash is to tell JSON, “I really mean a backslash here.”You escape the backslash itself.
Here is my sample logs
In JSON you really have to escape a ‘\’, but in a normal “content” log field, you upload strings, and they are not escaped…
Hello @AntonioSousa ,
That’s correct
You can change the log sample and add another \
Before:
After
Not sure if after saving this parse will work
… but at least is saved :wink:
HTH
Yos
