DQL For Apdex
I want to create a visualization for our application platforms having  apdex overview..
Is there any way to do it using grail or new functionality rather than configuring it in Data explorer.
Regards
Amita Chede
Hi @amita
I do not see a direct advantage of Grail over Data Explorer when building charts for Apdex.
You can think of your own application in Dynatrace built on AppEngine.
Radek
Thanks for the quick response Radek.
Regards
Amita
I assume you want to show Apdex values for applications or user actions on a dashboard.
Currently (Feb 2024) Apdex metrics or user session data are not yet in Grail and you can’t easily visualize it on the new dashboards or notebooks. For visualizing Apdex it’s still recommended to use Data Explorer + Dashboard classic or USQL.
There are workarounds using JavaScript as the data source, but I highly discourage you from using them unless necessary.
Understood.
Is there any chance Dynatrace is planning to get the user session data in grail in nearby future.
Yes, it will be available soon.
Useful resources:
https://community.dynatrace.com/t5/Developer/ct-p/developers
https://community.dynatrace.com/t5/DQL/bd-p/dql
https://community.dynatrace.com/t5/Automations/bd-p/automations
Hi Julius, do you have any update on the release period of it?
Thanks in advance
Would you know if there are any target dates for metrics that are being moved over to grail?
Unfortunately not. But there was a session at Perform (recording is available at https://perform.dynatrace.com ) showing it in action.
No, I don’t know. I believe the metrics in Grail will be available with the new frontend agents (see my post above) at least for web applications..
@amita I would suggest to have an apdex that signals good performance as a combination of Core Vitals and other metrics related to Web frontends and RUM on Grail. See below an example:
fetch user.events
//|filter frontend.name ==
| filter characteristics.has_page_summary == true
| filter isNotNull(web_vitals.first_contentful_paint)
  and isNotNull(web_vitals.largest_contentful_paint)
  and isNotNull(web_vitals.cumulative_layout_shift)
  and isNotNull(web_vitals.interaction_to_next_paint)
| fieldsAdd fcp_apdex = if(web_vitals.first_contentful_paint <= 1800ms, “satisfied”, else: if(web_vitals.first_contentful_paint <= 3000ms, “tolerating”, else: “frustrated”))
| fieldsAdd lcp_apdex = if(web_vitals.largest_contentful_paint <= 2500ms, “satisfied”, else: if(web_vitals.largest_contentful_paint <= 4000ms, “tolerating”, else: “frustrated”))
| fieldsAdd cls_apdex = if(web_vitals.cumulative_layout_shift < 0.1, “satisfied”, else: if(web_vitals.cumulative_layout_shift < 0.25, “tolerating”, else: “frustrated”))
| fieldsAdd inp_apdex = if(web_vitals.interaction_to_next_paint <= 200ms, “satisfied”, else: if(web_vitals.interaction_to_next_paint <= 500ms, “tolerating”, else: “frustrated”))
| fieldsAdd apdex_score = (
    0.25 * (if(fcp_apdex == “satisfied”, 1, else: if(fcp_apdex == “tolerating”, 0.5, else: 0))) +
    0.25 * (if(lcp_apdex == “satisfied”, 1, else: if(lcp_apdex == “tolerating”, 0.5, else: 0))) +
    0.25 * (if(cls_apdex == “satisfied”, 1, else: if(cls_apdex == “tolerating”, 0.5, else: 0))) +
    0.25 * (if(inp_apdex == “satisfied”, 1, else: if(inp_apdex == “tolerating”, 0.5, else: 0)))
| summarize score = avg(apdex_score)
@apasoquen1 offering an apdex metric is on our plans, I cannot give an accurate estimation but I see it in the 2nd half of 26
@manos-saratsis
Guys, I’m trying to use this DQL and I’m not getting any results:
fetch user.events
| filter frontend.name = "Portal Bra"
| fieldsAdd fcp_apdex = if(web_vitals.first_contentful_paint <= 1800ms, "satisfied", else: if(web_vitals.first_contentful_paint <= 3000ms, "tolerating", else: "frustrated"))
| fieldsAdd lcp_apdex = if(web_vitals.largest_contentful_paint <= 2500ms, "satisfied", else: if(web_vitals.largest_contentful_paint <= 4000ms, "tolerating", else: "frustrated"))
| fieldsAdd cls_apdex = if(web_vitals.cumulative_layout_shift < 0.1, "satisfied", else: if(web_vitals.cumulative_layout_shift < 0.25, "tolerating", else: "frustrated"))
| fieldsAdd inp_apdex = if(web_vitals.interaction_to_next_paint <= 200ms, "satisfied", else: if(web_vitals.interaction_to_next_paint <= 500ms, "tolerating", else: "frustrated"))
    0.25 * (if(fcp_apdex == "satisfied", 1, else: if(fcp_apdex == "tolerating", 0.5, else: 0))) +
    0.25 * (if(lcp_apdex == "satisfied", 1, else: if(lcp_apdex == "tolerating", 0.5, else: 0))) +
    0.25 * (if(cls_apdex == "satisfied", 1, else: if(cls_apdex == "tolerating", 0.5, else: 0))) +
    0.25 * (if(inp_apdex == "satisfied", 1, else: if(inp_apdex == "tolerating", 0.5, else: 0)))
When i use:
| filter dt.entity.application == "APPLICATION-F928FCDC7F9E61E8"
i also don’t get any results, other than null
