DQL Parsing on logs
We are currently trying to use the parse feature in DQL to parse out paths that end in different integers. The current format is V + an integer. How can we make it so we do not have to hardcode every possible version such as v9/start/order or v8/start/order/ In its current form, it only works for v10. Thanks!
We are using "| parse RequestedPath, “DATA ‘v10’ LD:path2"”
Hi @jordanb
You can use DPL macros to achieve this.
This DPL should work for your use case
| parse RequestPath,
  """$version = 'v' int;
  LD $version LD:path
Please have a look at pattern expression macros for further details: DPL Pattern Expression Macros — Dynatrace Docs
Best,
Sini
