DQL Timeseries: Unexpected Data Point Aggregation on different Intervals
we recently wanted to implement a feature with Dynatrace that alerts users if their namespace overrequests CPU resource in the Openshift Cluster.
As a basis for this feature, we were planning on using a DQL query similar to the following:
timeseries {
  requests = sum(dt.kubernetes.container.requests_cpu, rollup: avg), from: -3h, to: now()
}, by:{dt.entity.cloud_application_namespace}, interval:1m
The idea was to investigate the total request in a namespace. We wanted to represent this value as 1 data point per timeslice. We use ‘rollup: avg’ because using the default of ‘rollup: sum’ doesn’t make sense in this context because e.g in a situation where a namespace requests 1 CPU for 5 Minutes we want the output to also be 1 core because that is the only resource that has been occupied. Ideally we would like to take data points from the previous 14 days into consideration which limits us to use 15min intervals as the finest option.
The issue however we see is that if we run the query above against a random namespace and plot different interval settings for a fixed timeframe, the values of data points climb as can be seen in the attached screenshot. Our expectation is that the behaviour is tied to the ‘rollup: avg’ parameter. So we expect that the average of the entire timeframe stays similar no matter if the interval is 1m or 15m or 3h. However from what we see we assume that an additional aggregation method is used in the backend of dynatrace other than the ‘rollup: avg’ that is tied to the ‘sum’ aggregation method.
The question that we now have is if there is another approach to get the desired results or if a feature request can be opened to decouple the ‘sum’ aggregation method from whatever other aggregation is done in the background that is connected to the interval.
I personally use different approach where I am in full control which aggregation function is used at each stage and also can have more then 2 aggregation steps. IMHO is is also more clear to understand.
It is based on functionality that aggregation functions can be used on timeseries (arrays) with following syntax:
| summarize { aggr_ts=avg(ts[]) }, by: .....
How to apply this technique to this case:
  • CPU is requested (the metric in question) on the level of individual containers (aka. cloud application instance) and this metric has this granularity.
  • I would get data for each container and namespace individually (and of course for each interval) - we are interested at average on this level
  • When this data is available, we can sum up container’s data for each namespace.
Query look like this:
timeseries {requests_cpu = avg(dt.kubernetes.container.requests_cpu)},  from: -3d, to: -1h
, by:{dt.entity.cloud_application_namespace, dt.entity.cloud_application_instance }, interval:3m
, filter:in(dt.entity.cloud_application_namespace, {"CLOUD_APPLICATION_NAMESPACE-D1A8E94BF4D4BAB4", "CLOUD_APPLICATION_NAMESPACE-EE200D622E7A42F5" })
| summarize requests_cpu=sum(requests_cpu[]), by:{dt.entity.cloud_application_namespace, interval, timeframe}
When comparing results for different intervals, we can see that now chars overlap.
Note: I used my IDs of entireties, wider time range in different intervals to illustrate process so it is visible on my data.
