DQL to get process group for specific set of hosts
I need help to get process group for specific set of hosts using DQL.
Has anyone extracted it successfully?
AK
It returns all process groups IDs and visual name for host “XXXX”:
fetch dt.entity.host
| filter entity.name == "XXXX"
| expand runs[dt.entity.process_group]
| fieldsAdd process_group.name = lookup(
    [ fetch dt.entity.process_group ], lookupField:id, sourceField:`runs[dt.entity.process_group]`
  )[entity.name]
Maybe a better DQL query can be done.
Best regards
As single process group can run on multiple hosts, this query may contain duplicates, you can use dedup command
| dedup `runs[dt.entity.process_group]`, process_group.name
to get list of unique process group ids/names and one exemplary host id/name for each of them. Alternatively you can use summarize to get unique process group ids/names with array of hosts it runs on
| summarize {ids=collectDistinct(id)}, by: {`runs[dt.entity.process_group]`, process_group.name}
Kris
Hi @krzysztof_hoja / @AntonPineiro
Good Day!
I am trying to fetch the software technologies of the process group. Could you please help me achieve this?
Thanks!
I used this query to successfully get a list of processes that have a specific one agent version installed on them.
fetch dt.entity.process_group_instance
| fieldsadd   host_id=belongs_to[dt.entity.host]
|join[fetch dt.entity.host | filter contains(installerVersion, “1.307”) | fieldsAdd installerVersion], on:left[host_id] == right[id]
I would think that something like this should give you what you are after:
|join[fetch dt.entity.host | filter dt.entity.host in (host1, host2,hoste) ], on:left[host_id] == right[id]
