DQL to pull vulnerabilities for each host
Do we have DQL functionality available to pull vulnerabilities for each host?
Let me know if anyone has done it. I am looking for a DQL query to fetch vulnerabilities for each host along with other details.
Tijust1
fetch events
| filter event.kind == "SECURITY_EVENT"
| filter event.category == "VULNERABILITY_MANAGEMENT"
| filter event.type == "VULNERABILITY_STATE_REPORT_EVENT"
| filter event.level == "ENTITY"
| fieldsAdd vulnerability.id, vulnerability.external_url, vulnerability.external_id, vulnerability.references.owasp, vulnerability.url, vulnerability.display_id, vulnerability.description, vulnerability.references.cve, vulnerability.title, related_entities.services.ids, vulnerability.parent.davis_assessment.exposure_status, vulnerability.davis_assessment.exploit_status, vulnerability.davis_assessment.exposure_status, affected_entities.vulnerable_components.ids, vulnerability.stack, related_entities.databases.ids, vulnerability.parent.davis_assessment.score, vulnerability.technology, vulnerability.references.cwe, related_entities.hosts.ids
| expand related_entities.hosts.ids
| lookup [
    fetch dt.entity.host
    | fieldsAdd entity.name
  ], sourceField:related_entities.hosts.ids, lookupField:id, prefix:"host."
@PacoPorro Thanks for quick response. is there way to get in table format as I am getting result like belo
@PacoPorro my bad.. i got it. Thanks a lot for providing dql.
@PacoPorro is there way to get details for only one MZ. I mean if there is any filter option to choose certain MZ.
@sujit_k_singh
the above mentioned query will show you a lot of duplicates, as it shows you all the events from all snapshots, whereas you probably only want the most recent information.
for that you’d need a query similar to the one explained here: DQL examples for security data — Dynatrace Docs
slightly adjusted and adding the host information in the final table could e.g. look like this (changes in bold) :
fetch events<br>| filter dt.system.bucket=="default_security_events"<br>| filter event.provider=="Dynatrace"<br>| filter event.type=="VULNERABILITY_STATE_REPORT_EVENT"<br>| filter event.level=="ENTITY"<br>// get latest snapshot<br>| sort timestamp, direction:"descending"<br>| summarize {<br>vulnerability.parent.first_seen=takeFirst(vulnerability.parent.first_seen),<br>vulnerability.resolution.status=takeFirst(vulnerability.resolution.status),<br>vulnerability.mute.status=takeFirst(vulnerability.mute.status),<br>vulnerability.parent.resolution.status=takeFirst(vulnerability.parent.resolution.status),<br>vulnerability.parent.resolution.change_date=takeFirst(vulnerability.parent.resolution.change_date),<br>vulnerability.parent.mute.status=takeFirst(vulnerability.parent.mute.status),<br>vulnerability.parent.risk.score=takeFirst(vulnerability.parent.risk.score),<br>vulnerability.risk.score=takeFirst(vulnerability.risk.score),<br>vulnerability.parent.risk.level=takeFirst(vulnerability.parent.risk.level),<br>vulnerability.risk.level=takeFirst(vulnerability.risk.level),<br>vulnerability.stack=takeFirst(vulnerability.stack),<br>vulnerability.type=takeFirst(vulnerability.type),<br>vulnerability.external_id=takeFirst(vulnerability.external_id),<br>vulnerability.references.cve=takeFirst(vulnerability.references.cve),<br>vulnerability.technology=takeFirst(vulnerability.technology),<br>vulnerability.resolution.change_date=takeFirst(vulnerability.resolution.change_date),<br>vulnerability.mute.change_date=takeFirst(vulnerability.mute.change_date),<br>vulnerability.title=takeFirst(vulnerability.title),<br>vulnerability.davis_assessment.exposure_status=takeFirst(vulnerability.davis_assessment.exposure_status),<br>vulnerability.davis_assessment.exploit_status=takeFirst(vulnerability.davis_assessment.exploit_status),<br>vulnerability.davis_assessment.vulnerable_function_status=takeFirst(vulnerability.davis_assessment.vulnerable_function_status),<br>vulnerability.davis_assessment.data_assets_status=takeFirst(vulnerability.davis_assessment.data_assets_status),<br>affected_entity.vulnerable_component.name=takeFirst(affected_entity.vulnerable_component.name),<br>affected_entity.management_zones.names=takeFirst(affected_entity.management_zones.names),<br>affected_entity.name=takeFirst(affected_entity.name),<br>related_entities.hosts.names=takeFirst(related_entities.hosts.names),<br>related_entities.kubernetes_workloads.names=takeFirst(related_entities.kubernetes_workloads.names),<br>related_entities.kubernetes_clusters.names=takeFirst(related_entities.kubernetes_clusters.names),<br>related_entities.databases.count=takeFirst(related_entities.databases.count),<br>timestamp=takeFirst(timestamp)<br>}, by: {vulnerability.display_id, affected_entity.id}<br>// end of get latest snapshot<br><strong>//| filter iAny(in("i-05f1305a50721e04d",related_entities.hosts.names[])) OR affected_entity.name=="i-05f1305a50721e04d" // filter by name of the related/affected host</strong><br>// now summarize on the vulnerability level<br>| summarize{<br>vulnerability.parent.first_seen=takeFirst(vulnerability.parent.first_seen),<br>vulnerability.parent.resolution.status=takeFirst(vulnerability.parent.resolution.status),<br>vulnerability.parent.resolution.change_date=takeFirst(vulnerability.parent.resolution.change_date),<br>vulnerability.parent.mute.status=takeFirst(vulnerability.parent.mute.status),<br>vulnerability.title=takeFirst(vulnerability.title),<br>vulnerability.references.cve=takeFirst(vulnerability.references.cve),<br><strong>related_entities.hosts.names=takeFirst(related_entities.hosts.names),</strong><br>affected_entity.vulnerable_component.names=collectDistinct(affected_entity.vulnerable_component.name),<br>Critical=countIf(vulnerability.risk.level=="CRITICAL"),<br>High=countIf(vulnerability.risk.level=="HIGH"),<br>Medium=countIf(vulnerability.risk.level=="MEDIUM"),<br>Low=countIf(vulnerability.risk.level=="LOW"),<br>vulnerability.risk.score=round(takeMax(vulnerability.risk.score),decimals:1),<br>`Affected entities`=arraySize(collectDistinct(affected_entity.id)),<br>`# Non-muted entities`=countIf(vulnerability.mute.status=="NOT_MUTED"),<br>`# Afftected entities`=countIf(vulnerability.resolution.status=="OPEN"),<br>`# Function in use`=countIf(vulnerability.davis_assessment.vulnerable_function_status=="IN_USE"),<br>`# Exposure to internet`=countIf(vulnerability.davis_assessment.exposure_status=="PUBLIC_NETWORK"),<br>`# Exploit published`=countIf(vulnerability.davis_assessment.exploit_status=="AVAILABLE"),<br>`# Reachable databases`=countIf(vulnerability.davis_assessment.data_assets_status=="REACHABLE")<br>}, by: {vulnerability.display_id}<br>| fieldsAdd vulnerability.risk.level=if(Critical>0,"CRITICAL",<br>else:if(High>0,"HIGH",<br>else:if(Medium>0,"MEDIUM",<br>else:"LOW")))<br>| fields<br>vulnerability.display_id,<br><strong>related_entities.hosts.names,</strong><br>vulnerability.risk.level,<br>vulnerability.risk.score,<br>vulnerability.title,<br>vulnerability.references.cve,<br>vulnerability.parent.resolution.status,<br>vulnerability.parent.mute.status,<br>vulnerability.parent.first_seen,<br>status_sort=if(vulnerability.parent.resolution.status=="RESOLVED",3,else:if( vulnerability.parent.mute.status=="MUTED" OR `# Non-muted entities`==0,2,else:1)),<br>`# Function in use`,<br>`# Afftected entities`,<br>`# Exposure to internet`,<br>`# Exploit published`,<br>`# Reachable databases`<br>| sort status_sort, {vulnerability.risk.score, direction:"descending"}, {`# Function in use`, direction:"descending"},<br>{`# Exposure to internet`, direction:"descending"}, {`# Exploit published`, direction:"descending"},<br>{`# Reachable databases`, direction:"descending"}, {`# Afftected entities`,direction:"descending"}, {vulnerability.parent.first_seen,direction:"descending"}<br>| fieldsRemove status_sort
HTH,
Chris
Do we have the option to get the same infomation (vulnerabilities per host) in Dynatrace Managed without DQL?
Thank you.
hi @DamianG,
did you try using the Environment API v2, as described here: Vulnerabilities API - GET vulnerabilities — Dynatrace Docs ?
using the ‘relatedHostNames’ (or similar) for filtering via the ‘securityProblemSelector’ should be able to address your use case, I think.
HTH, Chris
