Has anyone integrated DT with PowerBI for environment api reports?
I want to use PowerBI for continuous reporting. Means Timeseries and Problem API chart should be feeding continuously to the PowerBI and we could easily customize the time frame for all metrics available.
This example gets a list of the hosts in the environment.
DON’T FORGET to add the http headers required such as the “Authorization” for the token and the “Accept” to specify you expect json data.
2. Once the data source is defined, because it is in JSON format, you need to convert it to a tabular format. In the example above it’s simple, but it could be that you’ll need to traverse through the JSON result first until you get to the array part that includes the result. Once there, “Convert To Table”
The above shows the results of the initial data source results. Use the “To Table” button to convert it to a table. Once pressed, you’ll that the yellow header now shows Column1 instead of List.
3. After your data is in a “table format” you need to create the columns to refer to in your reports. Just use the Add Column and refer to the field name you need. Codewise in PowerBI it is (for example):
= Table.AddColumn(#“Converted to Table”, “Host Name”, each Record.Field([Column1],“displayName”))
Repeat these steps as necessary. If you go to advanced query editor you may end up with the following query code:
#“Converted to Table” = Table.FromList(Source, Splitter.SplitByNothing(), null, null, ExtraValues.Error),
#“Added Custom” = Table.AddColumn(#“Converted to Table”, “Host Name”, each Record.Field([Column1],“displayName”)),
#“Added Custom1” = Table.AddColumn(#“Added Custom”, “OsType”, each Record.Field([Column1],“osType”)),
#“Added Custom2” = Table.AddColumn(#“Added Custom1”, “OsVersion”, each Record.Field([Column1],“osVersion”)),
#“Added Custom3” = Table.AddColumn(#“Added Custom2”, “Host Group”, each Record.Field(Record.Field([Column1],“hostGroup”),“name”))
in
#“Added Custom3”
4. Once you apply and save the query you are ready to build your report. Just choose your visualizations and drg the columns from the right part to the visualizations.
Than you so much for the reply, unfortunate that Dynatrace does not provide the templates. By chance have you found a way to handle the “Next Page” process? I’ve begun pulling a lot of data using the API but I constantly run into the page limits.
Is there some automated way to have the Query call NextPage and gather all the data? Until then many of the reports I’ve built I can’t fully use because they don’t tell the full story.
Hoooooo Great !
Here is what we are looking for for building our entreprise “Control Tower”. now we will be able to integrate Dynatrace Tiles in our PBI Reports !
very thanks for this post Gil ! and Take Care.
Hi - I too am creating a Power Bi (PBI) dashboard, but want to include the Dynatrace usage & cost data for our entire instance, about 10 individual tenants. In starting with the PBI webconnector, will I need to somehow integrate 10 different URLs and API tokens into one PBI dashboard?
