DT_CUSTOM_PROP and spaces
is there a (as of yet) undocumented way to get in values with spaces (key/value) metadata (or tags by using DT_TAGS). is there a way to escape spaces or using a special character interpreted as space in dynatrace?
we have the need to set a key ‘support_group’, and it needs to hold values like ‘department web - team1, department web - team2, …’.
thanks in advance, florian
As I know it isn’t supported right now.
Did this ever get addressed?
Yes, this would be really great to be supported either through quoting the value (key=“value with spaces”) or escaping with backslashes (key=value\ with\ spaces). Other tagging techanisms, including manual, AWS tag ingest, etc. allow for spaces. Why not DT_TAGS environment based tags?
Hello @florian_zimmerm  and @alex_luchs
As we know spaces are used to separate tag values until now. Therefore, please go ahead and open an idea to enhance the application’s capability.
Babar
Sorry for not seeing your reply for a month. Whoops!
I’ve created the product idea here: https://community.dynatrace.com/t5/Dynatrace-product-ideas/Add-support-for-spaces-in-tag-values-provided-by-environment/idi-p/177683#M27106
Instead of space, you could use a tab (is a tabulation character). this worked for me
Hi all,
We are facing a similar issue on our side with DT_CUSTOM_PROP
A couple of days ago, we have noticed a Dynatrace bug with DT_CUSTOM_PROP which translate “tabs” into “spaces”
We are benefiting from this bug as we are now using tabs whenever we need spaces… and as a workaround, this works for us including for auto-tagging !
In your example above, this would be
export DT_TAGS="value	with	spaces"
where there is a tab between value and with and another tab between with and spaces
This is seen better in below screenshot using vi with :set list
Tabs are represented as   ^I   special characters
Maybe this workaround will help while Dynatrace is considering the product idea to support spaces officially.
Hope this helps,
Kind regards,
David
unfortunately status: Not planned
You can use vertical tabs with alt + 0160. This also works in the GUI under Deployment status → OneAgents. Then select all OneAgents for which you want to add an environment variable tag and select “Modify host tags”. Then you can give it a key or a value with a space. At the location where the space is needed, just press alt + 0160 and your space will appear.
