But reached the same issue as the OP in that question, that the metrics ingest from the active gates responds with a 405. I’ve sent in metrics outside of kube with the same endpoint on a localhost:14499 OneAgent without issue, but here, the response is:
<body>Error: 405 HTTP method POST is not supported by this URL<br/>Uri: /metrics/ingest<br/>
api/v2/metrics/ingest also fails, but with a 404.
What is the working combination to get metric ingest in DynaKube?
Thanks for your response, but these just look like they’ve removed it from their samples, not the active gate. the comments in the code also suggest that is it still a capability of the active gate, even if it is not employed in the sample application.
for instance the code in the commit still has the following:
# Specifies which capabilities will be enabled on ActiveGate instances
# The following capabilities can be set:
# - routing
# - kubernetes-monitoring
# - metrics-ingest
# - dynatrace-api
Is there an official deprecation announcement of the capability?
