Help me with creating an alerting profile using api with severity level that is Custome_Alert
Metric event name - xyz with CPU saturation above 65% so - I want to create a alerting profile using DT api so only this metric event can be picked into alerting profile also auto tag we can add into script and event filters as required
Do help me with above need i was trying this with the help of DT documentation but only able to create alerting profile but as per the need i need to act so please provide an output on this
In line with your intent, I would rather recommend adjusting CPU saturation on the host or host group instead of creating a metric event. If it’s something you want to receive an alert for, I would take this approach instead.
However, if you don’t want to adjust the global setting and prefer to use a metric event, you can validate a precisely defined message title within the alerting profile.
You can create alerting profile in the UI with your filters and requirements. Later, select this API option, it will provide you POST request to create it.
