Dynatrace Activegate Supported OS
Dear Team,
Currently, we have Dynatrace Activegates (both Cluster and Environment) installed on RHEL 7 OS. Our Activegate versions are-
1.229.168, 1.257.216, 1.173.298
Could you please let us know the compatibility of Activegates on OEL 8 or higher versions?
@cp_patel
While 7.9 is still supported, going for a newer version is probably a better option. From
Hi @AntonioSousa ,
I have upgraded the ActiveGates OS for my managed UAT environment to 8.10 (RedHat Linux Enterprise)  but it seems not yet supported. do you think it will cause issues because we are planning to use the same version for the production environment. While 8.10 is supported for the cluster nodes
Managed system requirements - Dynatrace Managed Docs
