Our customer wants to implement Dynatrace on it’s Sharepoint 2013 environment. I remember that AppMon had some SharePoint integration but I cannot seem to find anything on that for Dynatrace.
Does anyone know of any such implementations? Looking through the documentation there is not such info about this.
Thanks!
We want to implement that too but only found that Dynatrace can only monitoring performance of Sharepoint installing some sort of complement on the servers, here: https://www.dynatrace.com/technologies/sharepoint-monitoring/
I knew about this, but it’s only the fastpack destined for AppMon i was mentioning in the original post.
I’m just curious if there is a way to monitor Sharepoint with the new Dynatrace.
Yes sorry you’re right, I just read it fast, hopefully they respond about that or just release a update for the new Dynatrace
Actually this fastpack was bunch of sensors and correlated dashboards. Generally it should be possible to recreate it in Dynatrace.
Based on the fastpack to AppMon, you can build your own plugin for Dynatrace using identical measurement points (included in the fastpack measurement point, they monitor the sharepoint comprehensively).
In principle, the solution is ready only you have to recode it to the new version.
If you want I can give you help because I will also need this plugin.
Thanks a lot for the feedback.
I’ll talk to the team and will keep you posted.
Br,
Sorin
Anyone installed oneAgent on Sharepoint Application ? If yes then at what level we are getting data ?
Any progress on SharePoint Extension for OneAgent ?
