Dynatrace API to fetch exceptions from Multidimensional Analysis
I’m looking for an API that can give exceptions occurred on specific time as I can see an exception analysis in multidimensional window. Kindly help me to figure it out the output through the API.
Also I need to pin the analysis in dashboard so I can see the graph directly from the dashboard.
Hi @Shruts,
I hope I understand your request.
You should create a metric about the filtered MDA (for the specific exeption), you need a proper filter, split by can not be merged services. Then you can vizualize it on Dashboards or you can export it via the environments apiv2 /metrics/query endpoint.
I hope is helps.
Best regards,
Mizső
Can you please give any other way because I can’t create matric because of 500 limitation per tenant. Let me know if is there any other way to fetch exception details through the API.
