Can I publish any other metrics other than the time series via API?
Cheers,
Yash
Cheers,
Yash
Can you give me some examples or use-cases?
Hi Yash,
What else are you looking to export from Dynatrace?
Thanks for the response guys.
I want to publish a metrics that is not based on time series for example.
My custom product agent vs the no of machines on which they are running.
like 4 machines are running on 1.x
and 5 machines are running on 2.x
I am looking to export into dynatrace ![]()
Cheers,
Yash
Understand, but where in your monitored topology you would like to put that metric on?
Thanks for the interest and response!
I am planning to add these under my microservices host. Our microservices is based on Go Lang.
Cheers,
Yash
In the long run we will also introduce key value properties on all types of components, such as host, services through API. But maybe writing a local Dynatrace monitoring plugin would allow you to collect all the meta info of the local running versions.
See here:
Don’t know how else to get this to you @Wolfgang B. but thank you and your team for making ‘from’ time an ISOTime in the V2 API. I’ve wanted this since I started using the APIs.
Thanks a lot for your positive feedback! I will let the team know.
Best greetings,
Wolfgang
