Dynatrace api v2, how to access host's schemaId (builtin:anomaly-detection.infrastructure-disk) using setting/object REST API
The information is accessible thru the UI and not thru the API
https://<tenant>/…/ui/settings/HOST-xxxxxxxxxxxxxxxx/builtin:anomaly-detection.infrastructure-disks?gtf=-2h&gf=all
Easier way would be, going to schema in the UI:
Select “…” → API:
As you can see there, it is not HOST-id, you need object ID. If you go to full API specification:
I would call all objects you are interested using filters (filtering by schema for example), get objects IDs, and make a second call to get details of ID (disk).
Best regards
Here are the results of my REST explorations
Evironment:
  • tenants:
    • 18
  • total Hosts:
    • 45k
  • SchemaId to check:
    • builtin:anomaly-detection.infrastructure-disks.per-disk-override
      • required to check that it’s not been disabled accidentally
Cynematics:
  • get hosts (18 multipage request)
  • for each host:
    • get /api/v2/entities/HOST-XXXXXXXXXXXXXXXX
    • from each host get: (tens of disks per hosts)
      • “toRelationships”: {
        “isDiskOf”: [
        “id”: “DISK-XXXXXXXXXXXXXXXX”,
        “type”: “DISK”
      • for each disk:
        • get /api/v2/settings/objects?schemaIds=builtin%3Aanomaly-detection.infrastructure-disks.per-disk-override&scopes=DISK-XXXXXXXXXXXXXXXX&fields=objectId%2Cvalue
Conclusion:
  • Estimated number of REST request on the schemaId: 45000 times ( average of 10 disks per hosts configured) is 450k
  • About 20 hours to get the informations at 10 millisec per request.
    • Tools used:
      • python 3.11
      • asyncio
This should be available at the HOST level just like the UI is offering, as it’s not practical to use the UI to check 45k hosts
