Dynatrace API with more than 500 output
Hi All
Why the output include only 500 items in the ouput even the Nextpagekey was mentioned.
Any idea?
The page size is 500, that’s why your result set is split into  3395/500 → 7 pages.
You need to issue 7 calls to Dynatrace API to get the full result.
You may want to try the pageSize parameter to return larger pages, but 5000 is the maximum anyway.
But how make 7 calls?
Changing time frame every call or how?
No you just copy the nextPageKey value, remove all the other filters and just call the same endpoint giving only the nextPageKey as a cursor. You will then get the next 500 entities and a NEW nextPageKey that you again enter as the cursor.
Thanks a lot @wolfgang_beer ,
I didn’t pay attention that the NextPageKey changes on every call.
Have a good day.
