Dynatrace associate exam preparation
Is there any way to compare my knowledge about Dynatrace before giving the actual exam?
If you have link for MOCK test, could you please share the link for me to test my knowledge before actual exam.
Do you have the DOC for Q/A for Dynatrace ex
You can find a test exam and training materials in the Preparation tab of the Associate Certification in Dynatrace University:
From my own experience, practice is your best ally. If you have access to a Dynatrace environment where to try things out, just try out all of the settings in Dynatrace and understand how they work. Also, just take some time to read through the Dynatrace Help pages to see everything that is doable with the product.
I totally agree with @victor_balbuena .
If you have time and any demo \ Free trial environment the best option to deploy simple application with classic tiers ( web - app - db) and have Hands-On.
Your own experience and practice will immediately remove any complexity from 75% of the questions.
The exam itself is very simple if you have worked enough with the product.
Good luck on the exam!
Alex Romanenkov
i don’t have full access for Dynatrace Demo trial Community/university please let me know, how can i get full access , please suggest or help me to get it
Ideally, you should set up a ticket used the Univesity request type and describe your problem.
You should be able to get a Dynatrace SaaS environment trial through dynatrace.com, if you haven’t used it up already:
If you have access to demo, it’s still worth checking all the settings and see what they do, even if you can’t create/modify them.
I have created and using but I am unable to change and modify them, please help me,
Please check screen attached
You probably need to give yourself permissions, then. Which is a good first thing to learn towards the Associate exam 😉
On the bottom left of your screen, go to Account Management, choose your Dynatrace account, and on the top bar, choose Identity Access and Management → People. On this new section, click on the triple dot on the right for your user, and choose to Edit user. Make sure to select all the groups needed, but Monitoring Admin should be enough:
Save, give it a couple of minutes, and see if that solves the issue.
More about user permissions here: User groups, permissions, and policies — Dynatrace Managed Docs
I am unable to find settings, please help me. please refer attached snap.
Hi Dynatrace Team,
Do we have results or answers for MOCK test to correct myself. i have passed but i am not sure which i was corrected the answers?
Hi
To verify the Q/A use quizlet.com. This has flash cards to test your knowledge before exam (Note - same question may not come in actual exam. This is just to verify the answers. Still suggest you to check for Dynatrace documents to learn more about it.)
https://quizlet.com/558155195/dynatrace-associate-cert-flash-cards/
Cheers!
RN
Very useful for DT beginners.
Great for beginners and awesome format. Thanks for sharing.
