Hi all,
I am planning to appear for the Associate Exam soon. So, I went through the LEARNING PATH which specifically mentions that PRACTICAL SECTION IS OPEN BOOK.
What does mean? Open book , as in we can check the steps from the documentation and then do the practical. Correct me if I am wrong.
Thanks!
@Tanya_Kaushal Yes, you should be able to refer to “https://docs.dynatrace.com/” or navigate to docs from the GUI. But its highly unlikely that you would have enough time to refer to docs and run though the steps during the exam. Its good to have hands on experience and practice well before attempting the certification.
