Dynatrace built-in registry
Is it possible to download a specific version of an OneAgent image directly from an Environment ActiveGate? (Built-in Registry)
Is there any difference between Classic Full-Stack and CloudNativeFullStack image?
Is this a correct sintax?
<env-activegate>:9999/e/<env-id>/linux/oneagent:1.317-43.20250702-125508
@helton_harada I think the Classic Full-Stack OneAgent image would be different, please see below options to download
Thanks for reply @p_devulapalli !
Yes, I agree with you. I was looking at the same Dynatrace documentation page you mentioned… It says that the image for Classic mode would only be available via built-in Dynatrace registry.
It still says it’s preferable to use the tool: “skopeo”
What will be the endpoint from which we could retrieve these images? Could we download it from an EnvActiveGate?
@helton_harada the way I understand it , the OneAgent binaries are downloaded from the Dynatrace cluster and the ActiveGate only acts as a proxy to route the download incase the cluster is not accessible directly from k8s cluster and if routing is enabled . AG does cache the images but I am unsure if we can download them directly from AG in a similar way
No. Only the server acts as a Docker registry. Also, it provides only x86 images. If it does not fit your deployment (unable to get the images or cpu architecture is different), use the images from a public registry uploaded to your private registry
 see Store Dynatrace images in private registries — Dynatrace Docs .
