There is an overview within the tenant available at:
Settings > Integration > Custom metrics overview
This will give you more insight into consumption. Metrics are consumed as @Radoslaw S. mentions. If you have multiple dimensions or more processes, you might easily find yourself consuming much more metrics than initially expected.
I have 66 Application Server (Processes) and 2 metrics (Hogging thread and Pending user request) so the calculus will be 2*66 and this will be correct.
As I casually discovered there is a way to see the actual consumpion per activated plugin as mentioned by @Julius L. : Settings > Integration > Custom metrics overview:
