I’m looking for a clear guide on implementing Dynatrace in our current ECS setup. We have an ECS cluster with multiple services and tasks running on it, and we’re using EC2 instead of Fargate.
I came across this document: Dynatrace AWS CloudWatch ECS Integration, but I find it a bit vague. I’m not sure what the next steps are after enabling service monitoring, as the metrics mentioned seem to be just standard CloudWatch metrics.
Could anyone guide me on the proper way to implement Dynatrace in this setup? Any insights would be greatly appreciated!
However… There are many different ways to deploy you can deploy via your build scripts (including agent pulldown and install), cloud formation templates , ansible it all depends on your environment and how you deploy your instances.,
Thank you for providing these documents. I was able to modify our Launch Template in ASG to automatically install Full Stack Dynatrace monitoring upon instance launch. I can see that it is installed correctly and sending data to our dashboard UI.
However, none of the containers running inside the ECS cluster are enabled for deep monitoring, and I’m not receiving any logs from the applications. I also tried manually restarting the processes I want to monitor, but that didn’t help either.
How can I ensure that any new instance launched by ASG will have all containers running on it monitored in Dynatrace?
