after migration to SAAS , integration on alerts is failing regularly with expired token.
I got confirmation of support “To remain efficient and avoid unnecessary calls to Entra ID, Dynatrace caches the JWS token. It continues to use the cached token until the destination returns a 401 Unauthorized.”
Advice :
- Increase the token lifetime → Less failures.
- Edit the anomaly settings for the API-GW service to ignore 401 errors.
both of the options are not realistic : Increasing the token lifetime will not be allowed by security AND will only decrease but will keep on occurring (but less frequent)
Anomaly settings on API-GW to ignore 401 errors, would give a false view, as there might be other causes for the 401’s wich we would be missing.
Anyone having same experience ? Any idea how to solve ? And why does DT not test on expiration before (re-)using the token ?
i will try answer
Entra ID access tokens are short-lived and can vary (often ~60–90 minutes by design).
I think you can try one of this options:
First option is create proxy/webhook receiver.
Dynatrace → your proxy endpoint
Proxy handles Entra auth, refreshes proactively (e.g., refresh when <5 minutes left), then calls API-GW.
No security exceptions, no “ignore 401”, full control (retries, logging, idempotency).
Second option is Use Dynatrace Workflows instead of the legacy notification integration.
Workflows allow:
HTTP Request with Credential Vault, and for advanced auth:
Run JavaScript to fetch a fresh Entra token “just-in-time” and send the request.
Why doesn’t Dynatrace check the token expiry before reuse?
- tokens aren’t always safely/consistently parseable/usable as a “trustworthy expiry source” across providers,
- standard integration pattern: use cached bearer → refresh on 401
