Dynatrace integration with Oracle Oauth 2.0
Can dynatrace integrate with oracle oauth 2.0 And if so, how
Yes it can.
Monitor your OAuth 2.0 protected APIs with Dynatrace Synthetic
Maybe this helps, depending on your use case :). I assume you’re looking at synthetics?
Apparently also for cloud automation but I am not very familiar with that yet. Authentication | Dynatrace Docs
thanks for your reply
