Dynatrace Intelligence system level prompt
I have a specific use case.
We have multiple Management Zones across different departments. We would like to use the Dynatrace Assist feature to query problems (for example, “what went wrong”), but when the AI generates the DQL queries, we receive a lot of noise from other departments. This reduces the effectiveness and relevance of the results.
Is there a way to define a kind of “system prompt” or default context so that Dynatrace Assist always applies a specific Management Zone or segment when querying data, ensuring the output is scoped to the relevant department?
Thank you in advance.
@Shea0410 Notebooks does seems to have an option to limit by segment, but if you are referring to “Assist” chat I don’t think it has the capability to understand the segments and limit data at this point of time
Awesome yeah that makes sense, i would have liked if there was a way to introduce a system prompt to see if we could make it automatically apply a segment to a users group. For example, first line support. It then automatically writes the DQL query, then applies a segment in the query to the production environment. Think it would be pretty cool if we could manipulate the query writing at the system level.
