We had a issue with some problem notification so I tried to find any related log entries for this to see if they where actually made, but was unable to find any.
We are running on Saas and sounds like these entries could be found on a managed solution in the server.log, if possible where are information regarding problem notification logged?
Can verify a event is triggered, problem made, alerting profile is notet in problem, alerting profile is linked correctly to problem notification - but anyway to verify that in this case webhook to 3rd party is made?
Have You tried to confirm logs/errors on this 3rd party webhook?
Even if You will get logs from DT they will only contain info returned from this 3rd party. So for sure less than 3rd party logs itself.
So I would go with this option as it leads to faster solving issue.
I am interested in confirming that Dynatrace in fact did send a problem notifications.
In this case it never arrived at 3rd party so for me the best way to diagnose this would be to start a Dynatrace end.
Event captured correctly - alerting profile affected on event - alerting profile correctly linked to problem notification - Custom webhook verified, test succesfull - 3rd party never received anything.
So would be nice to log that it actually did fire of this specific problem notification - I am aware the webhook is fire and forget so would not expecting a error message just verify that Dynatrace did its part.
Then You need to open support ticket to get some data form Support (log records)
Only scenarios when webhook failed for me was with SSL errors - DT is very strict about it and checks both: signing chain(beware of self-signed stuff) as well as SAN field (often missing - as most browsers aren’t forcing it event thou they should).
