Dynatrace Managed Cassandra Failed to Startup
The team is performing an upgrade from 1.280 to 1.282.
After triggering the upgrade from “Settings >> Automatic update”.
It’s been stuck on the 2nd node for 24 hours.
Upon checking, the logs of cassandra:
{DYNATRACE_PATH}/log/cassandra/debug.log
ERROR The native library could not be initialized properly
Our question:
  • How to fix the error?
  • How to prevent this error from happening when performing upgrade?
Abner
Hi @abnerlusung,
Could you please raise a support ticket? Maybe the solution will be interesting for the community.
Thanks in advance.
Best regards,
Mizső
@abnerlusung you should open a support ticket. Is there any chance your operating system is not one of the supported ones for 1.282? Also, there are likely other errors before that one indicating the real cause.
Hi @Mizső ,
I opened a support ticket and I will update this when they’ve provided a resolution.
Abner
I checked the requirements, and rhel 8.9 is compatible.
Support ticket has already been raised and will wait for the R&D team to share their insights.
Abner
Hi @Mizső ,
Dynatrace team cleared it’s a Cassandra bug.
-Djna.tmpdir=/opt/dynatrace-managed/cassandra/tmp-bin
Need to add the following code
Abner
