Dynatrace Managed Cluster Upgrade Fails - Cannot Connect to Mission Control via Network Proxy
Hello Community,
I am performing a Dynatrace Managed cluster upgrade and the upgrade is unable to start.
During the pre-check/reconfigure process, I consistently see errors similar to:
“Cannot connect to Dynatrace Mission Control via network proxy”
The cluster nodes have outbound connectivity configured through a proxy. However, the upgrade and reconfigure operations continue to fail.
What I have checked so far:
  • Proxy configuration appears to be configured.
  • Upgrade process does not start.
  • Reconfigure operation also fails.
  • Mission Control connectivity errors are reported in the events/logs.
Has anyone experienced a similar issue during a Managed cluster upgrade?
I was seeing a successful connection using the curl command
But the reconfigure is failing
Definitely look in the logs of the upgrade process (default in /opt/dynatrace-managed/installer/upgrade) . Any chance your proxy needs certificate and the one you provided has expired?
Or any chance your proxy blocks some requests to mission control?
One additional troubleshooting tip: If you are performing the Dynatrace Managed cluster upgrade through the Dynatrace UI, please check whether antivirus scanning is interfering with the upgrade or reconfiguration process.
In our experience, antivirus scanning can potentially interrupt Dynatrace upgrade operations. Before starting the upgrade, coordinate with your security team to temporarily disable antivirus scanning or configure the appropriate exclusions for Dynatrace Managed directories and processes, as recommended by Dynatrace Support.
Hello @Sohel_Rashid
Thank you for highlighting this point. It is also addressed in the storage requirements (Exclude data storage paths from antivirus scanning to prevent data consistency issues).
Babar Qayyum
