Dynatrace Managed installation failed with error: Failed to start Nodekeeper
Hi All,
I already to install Dynatrace Managed with installation source that was downloaded earlier, but the installation process is failed with error like this : “Installation of Nodekeeper failed with error: Failed to start Nodekeeper, error: Redirecting to /bin/systemctl start dynatrace-nodekeeper.service”
I attached log
Anyone please can help me ? whats wrong with installation process ?
20200828-160341-failed-install-of-dynatrace-manage.log (206 KB)
Hard to tell here. Are you maybe running SELinux? Also See “systemctl status dynatrace-nodekeeper.service” and “journalctl -xe” for details.
anyway, I recommend opening a support ticket to get it solved properly.
Hi Radoslaw,
Yes SELinux is running
This is capture from “systemctl status dynatrace-nodekeeper.service”
And this is “journalctl -xe”
[root@DCAPPDTCMGMT01 ~]# journalctl -xe
Aug 28 21:46:25 DCAPPDTCMGMT01 systemd[1]: Configuration file /etc/systemd/system/dynatrace-server.service is marked world-inaccessible. This has no effect as configur>
Aug 28 21:46:25 DCAPPDTCMGMT01 systemd[1]: Configuration file /etc/systemd/system/dynatrace-elasticsearch.service is marked world-inaccessible. This has no effect as c>
Aug 28 21:46:25 DCAPPDTCMGMT01 systemd[1]: Configuration file /etc/systemd/system/dynatrace-security-gateway.service is marked world-inaccessible. This has no effect a>
Aug 28 21:46:25 DCAPPDTCMGMT01 systemd[1]: Configuration file /etc/systemd/system/dynatrace-nginx.service is marked world-inaccessible. This has no effect as configura>
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd[1]: Reloading.
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd-fstab-generator[37403]: Failed to create unit file /run/systemd/generator/aps.mount, as it already exists. Duplicate entry in /e>
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd[37396]: /usr/lib/systemd/system-generators/systemd-fstab-generator failed with exit status 1.
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd[1]: Configuration file /etc/systemd/system/dynatrace-server.service is marked world-inaccessible. This has no effect as configur>
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd[1]: Configuration file /etc/systemd/system/dynatrace-security-gateway.service is marked world-inaccessible. This has no effect a>
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd[1]: Configuration file /etc/systemd/system/dynatrace-nginx.service is marked world-inaccessible. This has no effect as configura>
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd-fstab-generator[37422]: Failed to create unit file /run/systemd/generator/aps.mount, as it already exists. Duplicate entry in /e>
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd[37415]: /usr/lib/systemd/system-generators/systemd-fstab-generator failed with exit status 1.
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd-fstab-generator[37442]: Failed to create unit file /run/systemd/generator/aps.mount, as it already exists. Duplicate entry in /e>
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd[37435]: /usr/lib/systemd/system-generators/systemd-fstab-generator failed with exit status 1.
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd-fstab-generator[37462]: Failed to create unit file /run/systemd/generator/aps.mount, as it already exists. Duplicate entry in /e>
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd[37454]: /usr/lib/systemd/system-generators/systemd-fstab-generator failed with exit status 1.
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd-fstab-generator[37481]: Failed to create unit file /run/systemd/generator/aps.mount, as it already exists. Duplicate entry in /e>
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd[37474]: /usr/lib/systemd/system-generators/systemd-fstab-generator failed with exit status 1.
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd-fstab-generator[37500]: Failed to create unit file /run/systemd/generator/aps.mount, as it already exists. Duplicate entry in /e>
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd[37493]: /usr/lib/systemd/system-generators/systemd-fstab-generator failed with exit status 1.
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd-fstab-generator[37520]: Failed to create unit file /run/systemd/generator/aps.mount, as it already exists. Duplicate entry in /e>
Aug 28 21:46:26 DCAPPDTCMGMT01 systemd[37513]: /usr/lib/systemd/system-generators/systemd-fstab-generator failed with exit status 1.
Aug 28 21:48:24 DCAPPDTCMGMT01 rsyslogd[1588]: cannot connect to 172.17.21.140:514: Connection timed out [v8.37.0-13.el8 try You searched for error 2027 - rsyslog ]
Aug 28 21:50:35 DCAPPDTCMGMT01 rsyslogd[1588]: cannot connect to 172.17.21.140:514: Connection timed out [v8.37.0-13.el8 try You searched for error 2027 - rsyslog ]
Aug 28 21:52:46 DCAPPDTCMGMT01 rsyslogd[1588]: cannot connect to 172.17.21.140:514: Connection timed out [v8.37.0-13.el8 try You searched for error 2027 - rsyslog ]
Any clue about this ? I already opening a support ticket but still nothing respond from support
I’d recommend turning selinux into permissive mode or disabling it.
How did you resolve this?  I just got same error messages…
@holst  disable selinux or set it to permissive mode. I also recommend to uninstall Dynatrace Managed if it’s the first-time installation. Please don’t forget to unregister it from the mission control - there is a cmdline flag for the uninstall.sh script and rerun the installation. Your license may be already locked in mission control.
If you need selinux in enforcing mode for any reason, you can also install semanage and run the following (/xxx is the installation path of Dynatrace Managed in this example):
semanage fcontext -a -t usr_t "/xxx"
semanage fcontext -a -t usr_t "/xxx/.*"
restorecon -R /xxx
How did you resolve this?  Even I am facing the same issue “Failed to start Nodekeeper”. It’s a first-time installation.
Solution provided by @jullam should solve it.
However, new installation since 1.222 (https://www.dynatrace.com/support/help/whats-new/release-notes/managed/sprint-222/) should apply these commands automatically.
