Are all updates for Dynatrace offline incremental?
I.e.: do I have to first install ALL versions up to a certain version in order to be able to update?
Or can I simply ‘skip’ the old ones?
Is there any difference in that respect between the different components:
1) DT server nodes?
2) OneAgent?
3) AG/Synthetic etc.?
Daniel
Yes, incremental. For instance if you are on version 1.230 and you want to upgrade to 1.238 you need to install: 1.232, 1234 and 1.236 before.
There are dependencies:
1. First, you need to install cluster (server) upgrades. Cluster doesn’t support newer than itself AGs and OA.
2. Then, you install ActiveGates (AG). OneAgent will connect only to newer versions of AG. E.g. ActiveGate 1.237 supports OneAgents 1.237, 1.235 and older…
3. At the end you install OA.
