Dynatrace Managed proxy setting
I have an installed Managed Cluster, connecting successfully to Mission Control. I have my proxy setting configured in the Internet Settings, but this only displays the actual proxy hostname. Is it possible to retrieve the account used to authenticate the proxy? Also does this proxy setting also apply to the integration options; such as Slack, or is it exclusively for Mission Control?
Normally you should see the username for the proxy configuration in the CMC. If it’s empty, then the username is not used (proxy allows anonymous access).
For individual proxy settings (your second question), you can configure different settings in cluster.properties. See here for details. If you do not configure anything in the config file, then the values entered in CMC will apply also to webhook integrations.
