Advent of Code is an Advent calendar of small programming puzzles for a variety of skill levels that can be solved in any programming language you like. You don’t need a computer science background to participate - just a little programming knowledge and some problem solving skills will get you pretty far.
But can you use Dynatrace and DQL for solving those daily puzzles? But why not give it a try!
An example of the day one puzzle solved Dynatrace Security Investigator can be found in Dynatrace Playgorund at Dynatrace
