Dynatrace not displaying host in web GUI for Aws Bean stalk applications
After installing one agent using the .ebextensions way the host is not showing up in the Web in the list of hosts.
After inspection the oneagent was successfully installed and oneagent watch process is also running. The correct Dynatrace cluster server list are also shown .
Restarted the process as well.
Need to know if i am missing anything. Any help is much appreciated.
If the host is not reporting in Dynatrace some key things to check is :
- Pointing to the right cluster and the associated environment.
- Check firewall rules from both the host and the ActiveGate.
