on our Dynatrace instance this message is appearing:
What does it mean, exactly? That the OneAgent process should be restarted?
Thatâs telling you that youâll need to restart some of the processes that the OneAgent is monitoring. Monitoring of the processes shouldnât be impacted, but for the processes to pick up the new version of the OneAgent a restart is needed.
Hope that helps,
JH
Hi, I show you a detailed example
Hi JH
Is the ârestart processâ only solution ? It becomes difficult to restart the pods/process to restart in prod environment, every time OneAgent gets updated.
Suresh
This is not a correct solution. We should have a real event that can feed Davis.
In my corp, we had issue with big simultaneous auto update (massive IO usage on datastorage array)⌠If there has been an event triggered, it should have triggered Davis.
Is it possible for these processes to restart automatically?
We strongly suggest this RFE: Create New Informational Problem Type - Dynatrace Community but we would have MAJOR issues with DT forcing an auto restart for the processes as this could cause other concerns/issues.
