Everything seems fine and Kubernetes status is also showing OK but We are getting gap in graph is this behavior is normal? If now what’s the issue how we will fix this?
Connection status is also showing ok, we have 2 containerized AG below are the details of Namespace and PODS.
for your information We have 2 OpenShift which we have integrated with Dynatrace one is working fine no gaps but yesterday we gave integrated with another one which is showing this gap problem.
If you need to validate connectivity regarding the OpenShift Clusters feel free to check with designated teams the attached parameters : Network traffic — Dynatrace Docs
This metric graph is similar to a throttling behaviour one…I have already seen that once but in a cloud integration (Azure Event Hub, I am not sure) with Dynatrace…
Maybe, it helps to think about throttling and how to solve it
