Dear Team,
We are using Dynatrace SaaS and we have configured GUI based cloud native fullstack integration using below URL.
Post installation Dynatrace AG status showing Init:Imagepullbackoff issue, kindly suggest how to fix this.
Thanks and regards,
Dharm
try the below and look at the events at the end, it will give you a clue on why the image pull failed
kubectl describe pod <pod_name> -n dynatrace
Hi @dharm_0101
As @p_devulapalli you need to check the AG pod log to understand what is the issue.
Usually its certificate issue as described in ImagePullBackoff error on OneAgent and ActiveGate pods but there is also an issue with operator v0.14.0
HTH
Yos
