Self Service Summary
After deploying the Dynatrace Operator, the OneAgent pod and CSI driver pod are not running on all the nodes.
| Issue | Solution | Tasks | Alternative(s) |
| Not all the nodes are having the OneAgent pod/CSI pod running on them | Check with your K8S administrator the taint(s) on the nodes | Update manifest files with corresponding toleration(s) | Contact Dynatrace Support for further assistance |
This is a common scenario for customers that use taints on the Kubernetes nodes in order to restrain what workload are deployed on them. If it is required to have the OneAgent + CSI driver pods running on those nodes, these taints need to be added as a toleration in the dynakube and the csi driver manifest files. Modified manifests need to be re-applied.
In order to check if a node has any taints, execute following command:
kubectl describe node <nodeName>
Identify the following part:
Taints: key1=value1:NoSchedule
It means that the node has a taint and the same value has to be set as a toleration in the manifest files. Nodes can have multiple taints.
The toleration(s) would need to be added in the dynakube and the csi driver manifest files.
tolerations:
- key: "key1"
operator: "Equal"
value: "value1"
effect: "NoSchedule"
After the manifest files have been edited, execute following commands:
kubectl apply -f <yourDynakube>.yaml
kubectl apply -f <yourCSI>.yaml
The same applies if the used platform is Openshift.
The official documentation from Kubernetes that explains in detail how taint and toleration work can be found here: Taint-and-toleration
