Hello
Are the Dynatrace Certifications here still active Dynatrace - Credly
Can’t seem to open most of the learning paths.
Moses
Hello
Moses
Yes, you can check certifications availables in Dynatrace University.
Best regards
It looks like there are currently some issues or changes with certification availability.
Right now, only the certifications visible in Dynatrace University (Platform and Services Delivery) are actually available.
Credly, on the other hand, shows all badges Dynatrace has ever issued, including certifications that are already retired.
So it’s possible that someone earned a certification before it was retired, and still has an active Credly badge (for example valid for 2 years), even though the learning path and exam are no longer available.
That’s why Credly should be treated as a badge history, not as the current certification catalog — the source of truth is Dynatrace University.
Other Certifications are now being revamped and improved and should be available within Januara (all the four specializations + ambassador certification).
This is what I received from university support. (I already had an exam scheduled and have been contacted to cancel it as the exam is not available).
We are currently working to update the Specialist certifications and encourage you to look out for upcoming changes to the Dynatrace Platform Certifications.
Most likely there will be some announcements at Perform timeframe.
Thanks @Julius_Loman, I am hoping they won’t go away. I think the specialist certs are great especially given the depth of functionality in the Dynatrace Platform. Will keep an eye out for the announcements
Thanks @Julius_Loman, I am hoping they won’t go away. I think the specialist certs are great, especially given the depth of functionality in the Dynatrace Platform. Will keep an eye out for the announcements
