Hey Guys, I am trying to understand the agentless manual injection methods. I have been using JavaScript tag method for a while without any issues but I am just concerned that it loads the JS synchronously and let’s say if the JS takes time to load then it blocks the actual page to load which is NOT GOOD.
I can see there is another insertion method Code snippet deferred (asyncCS) which gets loaded asynchronously in the background and it doesn’t affect the page load.
I want to understand if we use this, will there be any disadvantages?
- If we change the monitoring settings in Dynatrace UI, do i have to update the snippet again on the pages?
- Will there be any missing monitoring data? I mean if the JS does not get loaded fully on time and page starts loading before that, will we miss anything in terms of metrics?
- Do we need to specifically mention “async” keyword while loading the script or this is built-in the JS and we just have to load it from the page?
Best Regards,
Shashank
