Does Dynatrace SQL Extension 2.0 support Dimension filleter using variable?
<span><span class="">version:</span> <span class="">"0.0.5"</span></span>
<span><span class="">minDynatraceVersion:</span> <span class="">"1.283.0"</span></span>
<span><span class=""><br><br>vars:</span></span> <span> <span class="">-</span> <span class="">id:</span> <span class="">ownerFilter</span></span> <span> <br><span class="">displayName:</span> <span class="">Filter</span></span> <span> <br><span class="">type:</span> <span class="">text</span></span>
<span><span class=""><br><br></span></span>
<span><span class="">subgroups:</span></span>
<span> <span class="">-</span> <span class="">subgroup:</span> <span class="">DB</span> <span class="">Invalid</span> <span class="">Object</span> <span class="">Count</span></span>
<span> <span class="">featureSet:</span> <span class="">DB</span> <span class="">Invalid</span> <span class="">Object</span> <span class="">Count</span></span>
<span> <span class="">ingest:</span> <span class="">metrics</span></span>
<span> <span class="">query:</span> <span class="">></span></span>
<span><span class=""> select</span></span>
<span><span class=""> count(*) as invalid_object_cnt,</span></span>
<span><span class=""> owner</span></span>
<span><span class=""> from dba_objects</span></span>
<span><span class=""> where status<>'VALID'</span></span>
<span><span class=""> group by owner</span></span>
<span> <span class="">metrics:</span></span>
<span> <span class="">-</span> <span class="">key:</span> <span class="">test.db_invalid_object</span> </span>
<span> <span class="">value:</span> <span class="">col:invalid_object_cnt</span></span>
<span> <span class="">type:</span> <span class="">gauge</span></span>
<span> <span class="">dimensions:</span></span>
<span> <span class="">-</span> <span class="">key:</span> <span class="">owner</span></span>
<span> <span class="">value:</span> <span class="">col:owner</span></span>
<span> <span class="">filter:</span> <span class="">var:ownerFilter</span></span>
