Dynatrace Terraform provider - some synthetics still using /api/v1/synthetic/monitors
Why is synthetic monitor provisioning in the Dynatrace Terraform provider split between the v1 API (for dynatrace_browser_monitor and dynatrace_http_monitor) and the v2 Settings API (for sub-resources like outage and performance settings)? Also, is there an ETA on moving the core browser and HTTP monitor resources over to the v2/Platform API when using Terraform?
Starting to notice more and more resources (for example new Clouds app for AWS) are also not supported in the provider, is Dynatrace moving away from supporting new v2 objects all together using Terraform?
Hi @danny_1
Why the split: The Terraform provider follows whichever API Dynatrace exposes for each object. The core browser and HTTP monitor definitions have always been in the v1 Synthetic monitors API. Newer options, like outage and performance thresholds, were added later as Settings 2.0 schemas, so the provider manages them as separate resources.
ETA for v2/Platform: I’m not aware of a public ETA. Dynatrace is moving synthetics forward, though: there’s a Platform Synthetic API, and Settings schemas already exist for parts of browser monitors.
Is Dynatrace dropping Terraform for v2? I don’t think so. The provider is still actively released. New features usually come to the API first and to Terraform later. The new Clouds AWS connections are one example: they don’t have a dedicated resource yet, but you can set them up through the API in the meantime.
Sujit
