EasyTravel alternatives
I usually use easytravel app for training for my team or clients. Unfortunately this app is legacy. What app do you recommend as an alternative to easytravel?
Radek
Hi @radek_jasinski
You can use the Dynatrace environment that’s available for partners.
Hoping it helps.
KR,
Peter
Thanks for your reply. Unfortunately using a platform is not an option. I’m checking out one promising app - will let you know in the near future:)
Radek
There is a newer version of a demo application that’s available in either Kubernetes or Docker that I like to use.
Publicly available on the Dynatrace github - so long as you can instrument with either of those technologies in a VM it should provide substantial data for you & your teams to get started.
