Hi Team, I’m facing the following error while installing EasyTravel in Ubuntu 22.04.5 LTS - VMware.
root@dt:/home/dt/Downloads/easytravel-2.0.0-x64/resources# ls<br>easyTravelConfig.properties easyTravelThirdPartyResourcesizes.properties iisexpresstemplate.config keystore.jks nginx.conf.template Users.txt<br>easyTravelDemo.jks easyTravelTrainingConfig.properties init.d.easyTravel logback.xml quartz_data.xml<br>easyTravel.properties easyTravelWarConfig.properties.template installChromeDeps.sh login-module.config quartz.properties<br>root@dt:/home/dt/Downloads/easytravel-2.0.0-x64/resources# chmod +x installChromeDeps.sh<br>root@dt:/home/dt/Downloads/easytravel-2.0.0-x64/resources# sudo ./installChromeDeps.sh<br>Hit:1 http://security.ubuntu.com/ubuntu jammy-security InRelease <br>Hit:2 http://in.archive.ubuntu.com/ubuntu jammy InRelease <br>Hit:3 https://download.docker.com/linux/ubuntu jammy InRelease <br>Hit:4 https://ppa.launchpadcontent.net/openjdk-r/ppa/ubuntu jammy InRelease<br>Reading package lists... Done<br>Reading package lists... Done<br>Building dependency tree... Done<br>Reading state information... Done<br>libasound2 is already the newest version (1.2.6.1-1ubuntu1).<br>libasound2 set to manually installed.<br>libatk-bridge2.0-0 is already the newest version (2.38.0-3).<br>libatk-bridge2.0-0 set to manually installed.<br>libcups2 is already the newest version (2.4.1op1-1ubuntu4.11).<br>libcups2 set to manually installed.<br>libgtk-3-0 is already the newest version (3.24.33-1ubuntu2.2).<br>libgtk-3-0 set to manually installed.<br>libnss3 is already the newest version (2:3.98-0ubuntu0.22.04.2).<br>libnss3 set to manually installed.<br>xdg-utils is already the newest version (1.1.3-4.1ubuntu3~22.04.1).<br>xdg-utils set to manually installed.<br>Some packages could not be installed. This may mean that you have<br>requested an impossible situation or if you are using the unstable<br>distribution that some required packages have not yet been created<br>or been moved out of Incoming.<br>The following information may help to resolve the situation:<br><br>The following packages have unmet dependencies:<br>libgbm-dev : Depends: libgbm1 (= 22.0.1-1ubuntu2) but 23.2.1-1ubuntu3.1~22.04.2 is to be installed<br>E: Unable to correct problems, you have held broken packages.
For that, I modified the below file
and removed the below package and continued with the installation process, and it got complete without any error.
libgbm-dev
But after that, it got stuck in this steps: https://community.dynatrace.com/t5/Start-with-Dynatrace/easyTravel-Documentation-and-Download/m-p/181271#:~:text=localhost%3A8094/main-,Linux,run%20%3CeasyTravel%2DInstallationDirectory%3E%5Cweblauncher%5Cweblauncher.sh,-Both
dt@dt:~/Downloads/easytravel-2.0.0-x64/weblauncher$ sudo chmod a+x weblauncher.sh <br>dt@dt:~/Downloads/easytravel-2.0.0-x64/weblauncher$ sudo ./weblauncher.sh<br><br>2025-07-27 01:01:34 WebLaunche INFO [Init] -----------------------------------------------------------------------------<br>2025-07-27 01:01:34 WebLaunche INFO [Init] easyTravel Demo Application - Copyright (C) 2010-2025 dynaTrace software GmbH<br>2025-07-27 01:01:34 WebLaunche INFO [Init] -----------------------------------------------------------------------------<br>2025-07-27 01:01:34 WebLaunche INFO [Init] Procedure: WebLauncher<br>2025-07-27 01:01:34 WebLaunche INFO [Init] Version: 2.0.0.3684<br>2025-07-27 01:01:34 WebLaunche INFO [Init] Build Date: Wed Jun 11 07:25:24 IST 2025<br>2025-07-27 01:01:34 WebLaunche INFO [Init] Platform: Linux 6.8.0-64-generic, amd64<br>2025-07-27 01:01:35 WebLaunche WARN [PluginFinder] Specified classpath directory 'C:\Program Files\IBM\WebSphere MQ\java\lib' not found or is not a directory.<br>WARNING: An illegal reflective access operation has occurred<br>WARNING: Illegal reflective access by org.apache.catalina.loader.WebappClassLoaderBase$1 (file:/home/dt/Downloads/easytravel-2.0.0-x64/lib/catalina.jar) to method java.lang.ClassLoader.registerAsParallelCapable()<br>WARNING: Please consider reporting this to the maintainers of org.apache.catalina.loader.WebappClassLoaderBase$1<br>WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations<br>WARNING: All illegal access operations will be denied in a future release
Any guidance will be very helpful
