easyTravel runEasyTravelNoGUI.sh - keep it running endless
do you have any idea how to keep easytravel working endless using runEasyTravelNoGUI.sh
I’m starting it with nohup but after some time easyTravel is going down:
2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad]     CustomerBaseLoad - Procedure inprocess DBMS state changed to STOPPING. Scenario hosts after change: <br>2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad]     B2BBaseLoad - Procedure inprocess DBMS state changed to STOPPING. Scenario hosts after change: <br>2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad]     MobileBaseLoad - Procedure inprocess DBMS state changed to STOPPING. Scenario hosts after change: <br>2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad]     MobileBrowserBaseLoad - Procedure inprocess DBMS state changed to STOPPING. Scenario hosts after change: <br>2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad]     HotDealBaseLoad - Procedure inprocess DBMS state changed to STOPPING. Scenario hosts after change: <br>2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad]     HeadlessCustomerBaseLoad - Procedure inprocess DBMS state changed to STOPPING. Scenario hosts after change: <br>2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad]     HeadlessAngularBaseLoad - Procedure inprocess DBMS state changed to STOPPING. Scenario hosts after change: <br>2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad]     CustomerBaseLoad - Procedure inprocess DBMS state changed to FAILED. Scenario hosts after change: <br>2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad]     B2BBaseLoad - Procedure inprocess DBMS state changed to FAILED. Scenario hosts after change: <br>2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad]     MobileBaseLoad - Procedure inprocess DBMS state changed to FAILED. Scenario hosts after change: <br>2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad]     MobileBrowserBaseLoad - Procedure inprocess DBMS state changed to FAILED. Scenario hosts after change: <br>2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad]     HotDealBaseLoad - Procedure inprocess DBMS state changed to FAILED. Scenario hosts after change: <br>2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad]     HeadlessCustomerBaseLoad - Procedure inprocess DBMS state changed to FAILED. Scenario hosts after change: <br>2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad]     HeadlessAngularBaseLoad - Procedure inprocess DBMS state changed to FAILED. Scenario hosts after change:
Ok for those who also needs to run it continuesly, I’ve added this script to crontab to run on restart and in this way it works all the time. For Ubuntu:
@reboot /opt/easytravel-2.0.0-x64/runEasyTravelNoGUI.sh
You may want to run it this way.
  1. @reboot/opt/easytravel-2.0.0-x64/runEasyTravelNoGUI.sh > /dev/null &
This will make sure you are sending the standard out to /dev/null and running it the background.
Thx but actually I’m sending logs to file because of some reasons :slightly_smiling_face: I’ve posted my command as an example.
I have installed EasyTravel on Linux, but I am unable to find the script runEasyTravelNoGUI.sh.
I have searched the main application directory as well as all subfolders. Is there anything I might be missing here?
