We have a Red Hat 9 server and wanted to run edgeconnect using podman. We tested the exact same setup on a raspberry pi there it works instant without any issues, but on red hat 9 we always get the error:
2025-11-05T14:41:16.955309617+0000 info [initialization] Searching for config files in path ‘/’.
2025-11-05T14:41:16.955928359+0000 info [initialization] Initializing configuration: Config .yaml file edgeConnect.yaml will be used.
2025-11-05T14:41:16.956043650+0000 error [initialization] Error during startup: Error while loading configuration: missing field `name`
we just needed to add --- in the first line and have the config start in the 2nd.
